Quick Dimension Problem
Message 1 of 8
How can I avoide getting zeros when creating dimension line with quick dimension command
please see the attached image. the Zeros indicates the line itself. how it can be avoided?quickdim.JPG
Replies (7)
Message 2 of 8
doe's anybody have any clue how to solve this problem?
thanks
Message 3 of 8
pendean
Community Legend
Community Legend
Are you double-clicking? I can't reproduce the effect. Post a DWG instead of a screenshot with the problem, put a big arrow at each location, and let's all have a look.
Also, your ACA version? Is it fully updated? Windows OS?
Message 4 of 8
I don't understand what do you mean by Double clicking?!
I atached the dwg and the arrows indicates the zero numbers which shouldn't be there...
I use Autocad Architecture 2012 ver. F.51.0.0
operating sys. Win 7
I tried it also in 2010 version and the result was the same.
Also tried to see if something in the settings option within the command can result this, but nothing seems to works
Message 5 of 8
pendean
Community Legend
Community Legend
When I use MOVE with a crossing window selection and pick what I think is one dimension line, AutoCAD reports I'm actually seelcting two. I've reattached your file, and moved the non-zero dim lines away: it appears you have horizontal as well as vertical dimensions being drawn.
Drawing my own lines in your file shows that I cannot repeat the problem. I don't think your lines are actually horizontal, but at a very small angle perhaps looking at the PROPERTIES settings.
Message 6 of 8
Yes you are right!
the lines weren't totaly horizontal.
Thank you very much!
Message 7 of 8
lathander
Hi there, I have the same problem. I have a huge file (not drawn by me) and correcting every single non-horizontal angled line is out of question . It would take ages. So my question is, is there a way to delete zero-valued dimensions only? or is there a way to straighten multiple lines . Like selecting a whole lot of them and give a command so they are fixed. Either perfectly horizontal or vertical. thanks in advance.
Message 8 of 8
pendean
Community Legend
Community Legend
Start your own thread please and post a portion of the DWG file.
