Quick Access Toolbar loses commands
proberts1
Message 1 of 30
proberts1
I seem to be having an odd occurance. I am running Architecture 2010. and no... that's not the odd occurance,...
I have added certian commands to my Quick Access Toolbar. Every few days or so the Quick Access Toolbar loses the commands that I have placed on it and I must reattach them. I use the "More Commands..." option from the drop down of the Quick Access Toolbar, bringing up the dialog box from which I drag the wanted commands onto the toolbar.The commands could stay on the toolbar for as long as a week, and other times they last just for the day.
Any suggestions would be helpful.
Thank You
Patrick
Replies (29)
Message 21 of 30
pendean
Community Legend
Community Legend
@rcooper9QDTF it happens to some users, there is no real fix: something is replacing your QAT with a default, dig a little deeper to find out why (it could be migrated content, you need to create and load a custom CUIx instead, could be a startup, or add-on, could be a shaky Windows Registry file etc.).
Message 22 of 30
doxale
I have same problem AutoCAD 2022 after migration from 2021
Message 23 of 30
pobrienFNE96
I appreciate the continued, long-lived conversation on this topic. It's February 2022 and I'm also having this intermittent QAT mystery! And no, no idea what could be triggering it ...
Message 24 of 30
pendean
Community Legend
Community Legend
@pobrienFNE96 wrote:
>>>>....I'm also having this intermittent QAT mystery...<<<
Intermittent means you have a trigger you have not had a chance to identify at play. Ask your IT folks to help "watch" your system the next time it happens.
OR.. you can open a support ticket from your Autodesk Account page here https://manage.autodesk.com/home/ (click on the ? icon to start)
Message 25 of 30
nbreese
This has also been an issue for me since I started using the program 7 years ago. I also tried all these solutions, but nothing worked. It has basically made the QAT a useless feature, so I found other ways to customize my user interface.
Message 26 of 30
pendean
Community Legend
Community Legend
Open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help: https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options/we...
Message 27 of 30
CADmgrMike
If I may add to this thread.
We are incorporating VMs as CAD machines.
Our QAT works fine until the VM goes to lock mode. When you unlock it, the QAT loses most of the toolbars.
A quick workaround that works is to change workspaces and then change back. The QAT comes back as expected.
This issue doesn't happen on a local pc.
Mike Porter
https://provostandpritchard.com/
Message 28 of 30
amalandfx
I'm working on a virtual machine, too. (Parallels on a Mac, for reasons).
This might be the common link? Thanks for the alternative workaround!
-Amanda
Message 29 of 30
robert.talleyPK3YM
This may or may not help:
I am running CIVIL 3D 2021, and every few days, my QAT loses all of the custom commands, and assigns about 5 that I don't want
Because I have a few dozen custom commands, I saved a custom workspace, and/or a ".cuix" file
When my custom commands disappear, I simply click customize workspace,
go to transfer, and open my file
This allows me to select all of my desired custom commands quickly and easily (on the right side of the window), and then drag them into the QAT (on the left side of the window)
This probably won't help to prevent the commands from disappearing, but it makes restoring them far less of a chore
GOOD LUCK
Message 30 of 30
pobrienFNE96
GOOD LUCK
Thank you sir! Great workaround.
