- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have been using property set definitions since they were introduced in ACA. I used to attach psd's through the style manager on the general tab. Now it seems the process is to select the block and attach the psd from the extended data tab of the properties palette. Here is my issue i have blocks/mv blocks in a "style" drawing, in this case i have my electrical blocks in an electrical styles dwg file. The psd is set to object base, block, mv block. I have it set to manufacturer, color, part number and a image property set up in it. I select the block, go to the extended data tab and attach the psd. I add this to the palette. When i go to a drawing in some cases the psd does not come in with the block and in others the psd data is not visible on the extended data tab. I want to see it so i can change the properties of each instance of the block in the drawing if needed. What am i missing here? Seems that when psd's were introduced you could only attach to mv blocks but seems that in recent releases you can attach the to regular blocks. I have created both mv and regular blocks of each block but have the same issues. I haven't been able to find any clear current instuctions on the correct process to do this. Thank you in advance
