- Mute
- Permalink
- Report
I found an problem with VBS that stop me of use Property Set Data and I can not find method to avoid. (image 3)
image 1 : In this image everything works correctly, I can use this formula to Tag my Block Object.
but when I use this in model space happen this:
image 2 : in this image everything works correctly
image 3 : In this image appears the error, in the formula "Concatenate_Name_Error" appears correctly the Tag that I wish use ("A-01"), but in the MV-Block appears something weird, appears just "-1", and I tried everything that I found in the Internet and this is the last hope to fix.
Image 4: Another error when dash minus is ahead any letter and a digit. (result is "0.000" but should be "-A01")
and this error/bug not just appears concatenating, always that a variable have value letter, dash minus/plus sign, and a number, appear this error.
How to fix this?
