Plot Stamp issue
Plot Stamp issue
Message 1 of 11
Plot Stamp issue
Can not change the height of the plot stamp detail. The info prints on the bottom of the print OK, I just need to reduce the height and text size.
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
PLOTSTAMP command
Click on the ADVANCED button on that pop-up
The new pop-up that appears are the only way to set anything different about that plotstamp text.
Help yourself.
Message 3 of 11
Thanks for your suggestion, but it did not work for me. It opened the tab,
but it was "grayed", and nothing worked. Another suggestion?
Grover
Message 4 of 11
leothebuilder
Plotstamp command, on the advanced tab you should see this: see attached.
Message 5 of 11
-FDC-
Try using a different font
Message 6 of 11
Victoria.Studley
Hi @Anonymous,
I'm sorry to hear the options are greyed out for you.
I found this recommendation in the AutoCAD Help topic for Plot Stamps: "If the options are grayed out, click the Save As button to save Plot Stamp settings in a new file."
Could you try this and let us know if it allows you to modify the plot stamp text height?
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Message 7 of 11
-FDC-
Maybe it's an "rtext".
Try with "rtedit".
Message 8 of 11
Victoria.Studley
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Message 9 of 11
Hi-Thanks for your follow-up. Have not had time to verify the fix, but will
let you know--yes or no.
Grover Taylor
Custom Cylinders International, Inc.
800-779-5544
Message 10 of 11
Suggestion worked!!
Thanks for the help
Grover Taylor
[email protected]
Message 11 of 11
Victoria.Studley
Hi @Anonymous,
Thank you for following up. I'm glad to hear it worked!
Victoria Studley
