place construct file on sheet
kostimea
kostimea
Is there a way to place construct files on a sheet? Drag and drop works, but it inserts the model view of the construct file. I would like to do this to spare the view files and do the annotations in the construct file.
Thank you
dbroad
I would strongly recommend that you avoid that workflow. There are many views that require the use of the same model file. Putting annotation in the constructs will likely waste more of your time than creating view files.  The project navigator really works best with construct -> view -> sheet process.  If you will be managing xrefs yourself, most anything should be possible though.
Architect, Registered NC, VA, SC, & GA.
