AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Page setup default
2 REPLIES 2
twox2
2356 Views, 2 Replies
Page setup default
twox2
I have a drawing file that has no page setups in it, but has multiple sheet tabs.
I click on the first tab and then page setup dialog box.
it has my copier setting as the device.
Then i click on the second tab and the page setup dialog box.
it has my plotter setting as the device.
Again, I have no page setups in this file.
how do I change the default without making a page setup?
thanks,
Page setup default
thanks,
2 REPLIES 2
rkmcswain
in reply to: twox2
rkmcswain
There is no "default", other than the "none" device.
Someone in the history of this .DWG file, has set those devices current in the respective layouts.
If you want to make a default, you can do the same in your template(s).
twox2
in reply to: twox2
twox2
I see how to do it now.  thank you
