Good morning!
We make pre-cast wall panels and cast slab and support ledges onto the walls. With @Anonymous 's assistance I have been able to set things up to have the wall numbers incorporated into the ledge schedules. Using object anchoring solved that.
I'm trying to incorporate the weight of the ledge(s) into the overall weight of the wall panel. To do so, I need to anchor a wall panel to multiple ledges that might be attached to a wall panel. So far, if there's only one ledge, the weight does get added to the wall panel weight. But that's anchoring a wall panel to a single ledge.
I was wondering if it is possible to anchor one AEC object to multiple other AEC objects. I can anchor multiple objects to a single AEC object. The schedule proves that.
I cannot attach a drawing due to proprietary reasons.
Thank you in advance,
Anthony
Please ignore above. I have found another method to use.
