- Mute
- Permalink
- Report
I am in the process of generating a separate package which is a suppliment to the main package for a project. The sheets from the suppliment will be incorporated into the main project, but many sheets from the main project will not be included in the suppliment.
My thought was to make a separate sheet set that shares layouts with the main set which I was able to do by making a copy and renaming the .DST file. Now I see that supposedly a single layout cannot exist in two sheet sets. I ended up working around this by creating a sheet in SSM with the same # and Name in each Sheet Set and was able to get them to appear in both. Want to find out if I'm creating a landmine of a problem down the road or if there is a better way to do what I'm doing. In the past, I beleive we simply selectively printed only the appropriate sheets but on that project it was cumbersome and at the scale of this project it will be worse.
Any suggestions/advice would be greatly appreciated.
