multi-view blocks
multi-view blocks
multi-view blocks
i have multi view block with attributes only in top view block. i have made the multi view block in AEC content and inserted into a new layout drawing but i am unable to extract the attributes (which i have defined in the top view block of muti view block) in the layout drawing. Please help!!
MetalFingerz
What do you mean by extracting the attributes ?
An mvblock being a gathering of blocks, within it, the blocks' states are frozen and their attributes or dynamic actions aren't accessible.
My requirement is to make a table with 3 columns in a layout drawing where i insert my MV block from AEC content
1. Description of MV Block (given as attribute in top view of each MV blocks)
2. Drawing Number of MV Block (given as attribute in top view of each MV blocks)
3. Qty (Count) of different MV block
dbroad
In ACA, you don't use tables, you use schedules.  Add property sets to your mvblocks and then you can schedule anything you want.
Architect, Registered NC, VA, SC, & GA.
