MULTI-VIEW BLOCKS
MULTI-VIEW BLOCKS
Message 1 of 13
MULTI-VIEW BLOCKS
I downloaded quite a lot of multi view blocks online. Please how can I arrange them to form a catalog so that I can easily access them when ever I want to use it in my project In AutoCAD architecture ?
Replies (12)
Message 2 of 13
In short, put them in a dwg that is on a shared location (assuming not working alone) and create a tool palette to access them.
Close any open AutoCAD Architecture project before doing the next steps (or file paths created will be relative to the active project and may not work)
Open the dwg file from the shared location and drag the objects to an empty tool palette (either from the model space or open style manager and drag from there). You can then edit the tools to add properties like Layer Key, insert scale etc. Once happy with your tools (and tested them) copy the tools to a Content Browser Catalog palette to share.
Make this catalog in a network location (using the add catalog tool in content browser) that all can access. They just idrop the pallet to their installed. If you update the catalog users can just refresh the palette to get new tools.
Wish MV Blocks were exposed in the styles browser, would be much simpler!
Message 3 of 13
Please, since am working Alone (not sharing content with anybody), is there no other way I can do this? Or must I still put it on a shared location path?
Message 4 of 13
David_W_Koch
If you are working alone, you can save the source file anywhere that is accessible to you.  Choose a place where you will keep it "permanently", as the tools will have paths pointing to that location.  Move (or even rename) the file, and the tools will not work (unless the referenced style is already in your current drawing).
I would still make a tool catalog as a way to make it easy to back up your palettes.  If you are saving your source files and palettes on your local hard drive, be sure to back them up frequently (after every change), to avoid losing them in the event of a drive failure.  (If you save them to a network location that is not backed up, back them up yourself, too.)
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 5 of 13
David_W_Koch
Indeed.
David Koch
Blog | LinkedIn
Message 6 of 13
Thank you. I got the first part of your message, but the second part I don't understand. How will I make a tool catalog?
Message 7 of 13
dbroad
That's actually the easiest part.  Start the Contentbrowser command.  Create a new catalog there or use the my tool catalog catalog.  Then drag-n-drop your palettes into your catalog.
Architect, Registered NC, VA, SC, & GA.
Message 8 of 13
I now understand. But there is still a problem. I tried doing what you suggested. I opened the content browser, I right clicked and then chose add catalog. I then chose the root folder where I saved the dwg files of the multi view blocks I downloaded. After that, the new catalog was created but it was empty. Why is this so? Or must my file extension be. atc?
Message 9 of 13
dbroad
First, when creating catalogs, I suggest you just leave them in the default location "...\My Content Browser Library\..."
Second, a new catalog will always start empty regardless of where you put it.  That is where dragging the tool palette tabs into the new catalog comes in.  Create the palettes first. Then drag-n-drop. AutoCAD Architecture must be running and the tool palettes must be visible.
Message 10 of 13
I still don't get how to do it. How will I create the palettes for the multi view blocks? Don't forget that the multi view blocks I downloaded are in dwg format. Will I have to drag the dwg files of the multi view blocks to the pallete I created in the tool pallete tab?
Message 11 of 13
dbroad
Have you tried anything yet?
Message 12 of 13
Yes.. . But still haven't gotten it
Message 13 of 13
David_W_Koch
Start a new drawing from your template file.  Copy all of the Multi-View Block Definitions that you have acquired into that one file.  (You could have a separate file for each, but, for me, that is just more files to manage.)  One way to do that:  Use the Style Manager to copy them from the individual files to your new file.
Save your new file to its permanent location.
Open the file from that location (if you closed it).
If you use the Drawing Management system (Project Browser and Project Navigator), and you have a project open, close all related files and then close the project itself.
Start a new palette in your workspace, by right-clicking on the Tool Palette title spine and choosing New Palette from the context menu.  Give the palette a meaningful name.  Make certain that the Tool Palettes are open (either docked or, if floating, turn off auto-hide).  Bonus points for right clicking on the tool palette tab, choosing Properties from the context menu and providing a Description of the palette so that you will remember what is on this palette.  This description will show in the Content Browser.
Open the Style Manager.  In the left pane, expand the Multi-Purpose Objects node under your source file drawing.  Then select the Multi-View Block Definitions node.
In the right pane of the Style Manager, you will see a listing of the Multi-View Block Definitions in the source file.
For each Multi-View Block Definition for which you want a tool:
  • Position the cursor over the name of the Multi-View Block Definition (Style column).
  • Press and hold the left mouse button down.
  • With the left mouse button still held down, drag the cursor from the Style Manager to a position over the newly created Tool Palette.
  • Release the left mouse button to "drop" the Multi-View Block Definition on the palette.  This will create a tool.
After all of the tools are created, right click on each tool in turn, and choose Properties from the context menu.  Provide a description for the tool, if it does not already have one (inherited from the description of the Multi-View Block Definition).  Examine the other properties that are available.  Set the appropriate Layer Key and any default values that make sense for that content.
When you are done editing the tools, open Content Browser.  Create a new catalog if you do not already have one for this palette.  Open the desired catalog.  Right click on the top title bar of Content Browser and choose Always on Top.  This will make it easier to drag the palette into the catalog.
Position the cursor over the title tab of your tool palette, press and hold the left mouse button down and drag the cursor from the palette tab to the right side of the Content Browser (with your catalog open), and drop it into the catalog.
If you plan to store a number of different palettes in one catalog, you may want to create categories to organize the palettes into groups of similar palettes.  The categories will appear in the left pane of the Content Browser; you can create (sub-)categories within parent categories, if that works with how you want to organize things.  (Think folders in File/Windows Explorer.)  Or you can keep all the palettes at the "top level" of the catalog and not have any categories at all - whatever works for you.
David Koch
Blog | LinkedIn
