Model to layout issues
Message 1 of 9
I am sooo confused as to why:
1) What I have in the model does not display in the Layout.
2) Change my linework to dashed and it reverts to solid looking though the properties still show it as dashed..
3) Even though I am working in 2d..when I turn on the Iso views I see different levels but cannot get them all onto 0 level
These are three of my MOST frustrating issues..
Please Help!!
Ron Wright
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
In your posted file, which layout/viewport is the problem?
Thre are xrefs missing, are they critical to what is in modelspace? Notes from what I can tell.
Message 3 of 9
Thanks for your reply.
I simply want to see what I have drawn on the Layout, all of it...notes,
dimensions, hatching.
What can you tell me that may help?
Thanks in anticipation,
Ron Wright
Message 4 of 9
pendean
Community Legend
Community Legend
See attached: I see no issue doing what you want in your file with 11 missing xrefs.
Message 5 of 9
Thank you for your input. I suppose I need more time to understand the program as I am a beginner. Not sure what an "xref" is though I do see it.
Thanks again.
Ron Wright
Message 6 of 9
pendean
Community Legend
Community Legend
examine the file I posted, go into the layout, is that all you wanted?
Message 7 of 9
dbroad
I see that you are a beginner. Though the forum does not substitute for a classroom and for a a training course, I note the following:
1)You have not done yourself any favors by using a true color of 255,255,255 for the hatch layer, a layer on which you have a few viewports. Those viewports completely disappear on a white layout background.
2)You are using annotative scaling without any idea of what that involves.  Your model space is set up for an annotation scale of 1:1 which isn't how annotative scaling works.  Your model space annotation scale should be at 1/4"=1'-0" if that is the scale you want to plot at.  Your dimensions are marked annotative but they have individual settings that are tailor made for 1/4"=1'-0" rather than for plot size.  All settings in an annotative dimension style should be how big you want something to plot, not how big you need to make it to show up at a particular scale.
3)Your layout viewports are correctly set to 1/4"=1'-0" but ANNOALLVISIBLE is set off (meaning that only annotative objects marked for 1/4"=1'-0" will show).  Turning ANNOALLVISIBLE on will solve your immediate problem but should just be considered a short term workaround.
My strong recommendation is that you take a beginning AutoCAD course.  There are online courses available and probably some available near you.  I teach an online course called ARC 114, https://www.nashcc.edu/courses-programs which should get you through these basics. Unfortunately, the next session of that class begins in the Fall.  See if you can find training on annotative scaling and layouts.
I forgot to answer your question about xrefs. External references are separate files that are referenced into another file. Your external references appear to be image files containing general notes (not the most efficient way to manage textual information by the way.).  When I open the file, it states that it wasn't produced using AutoCAD.  It might be good to know what program you are actually using to do the drawing.
Architect, Registered NC, VA, SC, & GA.
Message 8 of 9
Thank you so much,
you helped me with a direct answer to some of the issues I am experiencing. I shall definitely take a course.
Wish you were nearer and sooner...
Ronald Wright
Message 9 of 9
dbroad
Our online course is as close as your computer but in time it is far away.
