Model Space View in Sheet is blank
ACA 2014 - I've created a model "Ground", Created a Section/Elevation View named "V Ground", inside that I've created a Model Space View named "MSV Ground". The view is a top-down 2d drawing (i.e. a plan) and the MSV rectangle is around it without much space. Scale is 1/100. I've then created a sheet named "S Ground" and added the MSV to the sheet. It appears to be the correct size and scale but is blank. It's only the border and a background grid (neither of which I want BTW). I'm not using any layers. Why is it empty?
jorgeseptien
Would it be possible to get a copy of that drawing(s)?  Off the top of my head I can only think that either the ground was put on a layer that is frozen or that the actual frame of the viewport is turned off (right-click on the viewport and look for "display viewport objects" and make sure it is set to yes.  But if that were the case, you would not see the grid.  I would try and figure it out if I could see the actual drawing.  Can you post it?
Jorge Septien
leothebuilder
Could it be that the construct xref in the view drawing is set as "overlay" ?
If so, it won't attach to the sheet file.
