Hi @dhassler,
I'm sorry to hear these suggestions didn't help. There are a couple of known causes for the particular error you're encountering here:
You can only open the Content Browser once on a machine.
- If you try to open a second instance, that error will appear: "The catalog you are trying to access...".
- Check first to make sure the Content Browser is not still open, but hidden behind something else, or located on a secondary monitor.
One or more of the content packs did not install correctly, and the files are missing from the installation.
- The same error will appear, and list the location of the content.
- Check the content folders to ensure the content packs you've installed are present. Default location: C:\Program Data\Autodesk\ACA 20XX\enu\AECContent\
- If the content is missing from this location, you need to reinstall the content packs or copy them from a working machine.
Finally, it looks like the path you've listed doesn't designate a particular drive. Do you use redirected user folders? This could be causing the problem.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
