Mirror command pop up disappeared
When using mirror command I used to get a pop up next to the cursor asking if I would like to delete the source objects
Now it has disappeared. I still get the choice on the command line, but the pop up was useful as you could choose with a click of the mouse
I have tried a switching selection cycling on and off and also the DYNPROMPT variable but neither change anything
dbroad
What is the dynmode setting?  Is it positive?
Architect, Registered NC, VA, SC, & GA.
pendean
Community Legend
Community Legend
Set DYNMODE to 3 (not -3 or anything else) and see if that helps.
pendean, perfect, thank you
haines.300
Thanks, I had the same problem! It's a mystery when things like this seem to spontaneously appear or disappear. I know that I did not enter DYNMODE and change the command!
pendean
Community Legend
Community Legend
@haines.300 You will never ever know for sure when any variable changes (and to figure out why) unless you add that variable (and any others you 'must have" to SYSVARMONITOR command's watchlist and have the program flag it when it changed https://www.google.com/search?q=how+to+use+sysvarmonitor+command
HTH
