If you installed content to the default folders, you should find the source files for US Metric content here:
C:\ProgramData\Autodesk\ACA 20xx\enu\Styles\Metric
Substitute the release year of the version you are using for 20xx.
If you open the Options dialog, and go to the Profiles tab, do you have an AutoCAD Architecture (US Metric) profile? If so, set that current. Select the OK button to return to the drawing. You should get the US Metric tool palettes, which will have more palettes and more tools. If the Design tool palette group is not current, right click on the tool palette title spine and choose Design on the context menu.
Then choose the Walls palette. You should see the options shown in the image below, along with a More Wall Tools tool that will open the Content Browser to the Walls category, which will have a tool for each Wall Style in the source file. CMU-190 should give you similar results to what I showed in my post above (from the Imperial content).
You can also access the out-of-the-box source files from the Style Manager (Manage ribbon tab > Style & Display panel > Style Manager tool; use the Open command to open the desired source file(s), from which you can drag and drop onto the current drawing in the Style Manager) or through the Styles Browser. For the AutoCAD Architecture (US Metric) profile, the out-of-the-box source files should already be in the Content Drawings Library, so the styles in them should be available in Styles Browser if the source is set to Content Library Drawings and the Drawing File is set to All Drawings. Set Object Type to Wall to see the available Wall Styles.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
