Material scale changes during rendering
fluffybunbun22
Observer Observer
fluffybunbun22
Observer
Observer
I've applied a predetermined metal fencing material to an object and edited the scale to 0.1 because of meters unit. It looks fine in the model but out of scale when rendering, what am I doing wrong? It only happens with this material
eizinmyat
How about checking with this way of material preview when scaling?
https://www.cadtutor.net/forum/topic/16114-material-scaling/
And  continue rendering ?
https://forums.autodesk.com/t5/autocad-forum/i-can-t-render-certain-materials-properly/td-p/7446377
Ei Zin Myat
Technical Sales Unit Engineer
ONESTRUCTION Co., Ltd.
eizinmyat@onestruction.com
odin
The Render Material you see in Shaded Mode is only the Render Image File and not the other settings such as Reflectivity, Cutouts, etc.  It appears to me that there is an incongruity among your settings.  I recommend  that you look at your Cutouts and Bump settings, set to Link Texture Transforms (if off) and verify that those match what you have set for the Image settings.
Odin Cary
Principal, ARCHIdigm
www.archidigm.com
Content Library Products now available for 2025
