Lost the xref pallet / dialog box
Message 1 of 24
I use 2013.  The xref pallet was docked but has disappeared.  Also, when I type 'xref' at the command line, the xref dialog box does not appear. How do I get them back?
Replies (23)
Message 2 of 24
pendean
Community Legend
Community Legend
off-screen perhaps? reduce AutoCAD/ACA from full screen in Windows (do not minimize it), then toggle XREF on and off a few times and see if you notice anything popping on/off at the edges of your monitor.
Or did you recently change from a dual-monitor setup?
Message 3 of 24
Got it back! Thanks for the info. It was lost off to the right. But in
release 2013, I don't have a good way to toogle on/off. I spoke with a
gentleman on the phone who had the second part of the fix. He sent me to
the CUI (Customize User Interface) box. I hit 'Current', 'Pallets' and
then 'External Reference'. Once there, I changed the location from 'Right'
to 'Floating'. This brought the dialog box back.
Thanks again,
*Mr. Jim Burris, LEED AP*
*Lamson & Condon Architects*
151 N. Delaware Street, Suite 151
Indianapolis, IN 64204
Wk: (317) 266-9830
Fx: (317) 266-0468
Mb: (317) 626-0887
Em: jburris@lamsoncondon.com
Message 4 of 24
TomBeauford
Thanks jburris, in one workspace the palette was Off and in another the location was set to Right.  Set them both to On and Floating and I have my dialog box back.
Thanks again,
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 5 of 24
revitpeon
What finally worked for me was to create a new workspace from the default 2D Drafting and Annotation space I was using by hitting Save As, then switch back to the default space.  The workspace I created still has the missing XREF manager, but that's okay, I can just delete it now.  Weird bug.
Message 6 of 24
2016 Autocad MEP I have lost the xref pallet. Same as below I type in XREF and is does not come up. I turn it off and on But I dont see it anywhere. any other ideas?
Message 7 of 24
David_W_Koch
Welcome to the community!
Did you try using the CUI (Customize User Interface) command, and changing the orientation of the External References palette in the current Workspace, as noted above?  Also make certain that the Show property is set to Yes.
The name of your current Workspace will be different that shown below; select the one that has " (current)" appended to the end of the name.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 8 of 24
Rex1054
To David Koch 4 years or so later THANK YOU! (11PM with deadline tomorrow & xref pallette disappeared...It's a little different in 2017 but it worked.
Message 9 of 24
David, thanks from 2018. Yes this problem still exists
Message 10 of 24
thank you. that was the most reasonable solution I found with excellent presentation. thank you for the time and effort your put. very much appreciated. I had it on the civil but as I switched to map it would disappear on my but now I got it back thank you for your nicely done resolutions. bravo
Message 11 of 24
Thank you!
Message 12 of 24
Fantastic!! It is almost 2020, and I am using 2018 version, and yet it still works!!
Thank you
Message 13 of 24
I'm using 2020 and this is still a problem. I cannot believe that the xref manager can be set to be invisible. What the actual **** Autodesk. The amount of productivity I loose to stupid stupid things like this is unreal.
Thank you for posting this solution, you've made my day a lot better.
Message 14 of 24
mhathorne
Community Visitor
Community Visitor
If you have lost the pallet between two monitors, unplug the secondary monitor where the pallet was lost (the monitor not showing your CAD file). The pallet will appear. Plug the secondary monitor back in. Fix time: 10 seconds.
Message 15 of 24
Thank you very much for your help!  Your solution worked!
Message 16 of 24
5 years later, this still works like a charm.
Thanks a lot!
Message 17 of 24
mariajose_berbelcosta
Community Visitor
Community Visitor
quick question:
structural cadworks doesn't show the xref palet
any sugestions?
Message 18 of 24
koolinour
Observer
Observer
Thank you very much
Message 19 of 24
nancronw
I tried this & when I hit the 'Accept" button, I again got the "Fatal Error" message.  Is the fact that I am using the 2912 LT version & have Windows 11 the problem?
Message 20 of 24
pendean
Community Legend
Community Legend
@nancronw wrote:
...Is the fact that I am using the 2912 LT version & have Windows 11 the problem?
LT2012 in Win11? I suspect it is so, you are two Windows versions beyond the ones LT2012 is designed to run in
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirement...
