AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
LISP/Command to match object classification between objects?
0 REPLIES 0
Message 1 of 1
jose.paredes9CU28
315 Views, 0 Replies
jose.paredes9CU28
I often have to input specific client-based classifications into objects (mainly spaces but also walls, doors and windows).
This is time consuming as I have to click into each entry and choose between the classification list my client has provided.
It would be faster if I could choose a similar object and "match classification" in the same way the MATCHPROP command works.
Is there a way to do this with a LISP? Thank you for your help.
Labels (1)
  • Lisp
0 REPLIES 0
