Layout Tabs
Layout Tabs
archanajain1
Message 1 of 9
Layout Tabs
archanajain1
I have several Layouts on a file, earlier I could move the layouts by clicking and dragging to end or per the sheet numbers.
it no longer lets me move the layout tabs.
any solution what I would have done?
I had to reinstall my Autocad Architecture 2025 and since then its not able to do this.
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
@archanajain1 Can I ask you to provide a screenshot of where you are trying to move your layouts please?
Message 3 of 9
archanajain1
 if you see below I have a few tabs, earlier I could move them and now am unable to move. there isa red circle with line there.
Message 4 of 9
pendean
Community Legend
Community Legend
@archanajain1thank you for the image.
You opted to cut it off, but it appears your commandline is in the middle of a process or command?
Message 5 of 9
archanajain1
no there was no command in process, it has never happened, so trying in uninstall and reinstall again. earlier I was able to move the tabs by dragging them in order I wanted. so batch plot is easier and in order.
Message 6 of 9
archanajain1
Reinstalled again but the problem still persists
Message 7 of 9
archanajain1
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-A8C1E8DA-56FA-4957-8FE3-7E54DEF7CC83
so this is what I am unable to do, move the Layout tabs and rearrange them. Any help here how to fix this?
Message 8 of 9
pendean
Community Legend
Community Legend
@archanajain1
1) RESET AutoCAD, not reinstall. Avoid any migration of saved settings for now. See if that helps.
2) log in as an all new user with full admin rights on the PC: does the issue go away?
3) Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
Message 9 of 9
archanajain1
I had to uninstall some updates and it worked. I created a ticket and they helped.
