Is this spec good enough to AutoCAD Architecture?
keronbwan70
keronbwan70
Community Visitor
Community Visitor
I'm looking to get a machine to run AutoCAD Architecture and I have seen a machine with the spec below. How well is likely to run on it https://mobdro.bio/ ?
  • 500W ATV Pro 80plus Certified Power Supply
  • ASUS PRIME B660M-A WIFI D4 Intel B660 PCIe 4.0 mATX Motherboard
  • Intel Core i5 12400F, S 1700, Alder Lake, 6 Cores, 2.5GHz, 4.4GHz Turbo (Graphics Card Required)
  • Cooler Master Hyper 212 Black Ed. Intel/AMD CPU Cooler
  • 32GB 2666MHz DDR4 (2x16GB) - Major Brand
  • PNY T1000 Professional Graphics Card, 4GB DDR6, 896 Cores, LP 4 miniDP 1.4
  • Intel® Optane™ Memory 32GB + Intel® QLC 3D NAND SSD 512GB, M.2 80mm PCIe 3.0
  • 2TB SATA III 6GB/s 7200rpm 64MB Cache 8ms
  • Integrated 7.1 High Definition 8-Channel Audio
  • 2x2 Wi-Fi 6 (802.11 a/b/g/n/ac/ax) Supports 2.4/5GHz frequency band Bluetooth v5.2
  • Microsoft Windows 11 Professional 64 Bit.
pendean
Community Legend
Community Legend
Other than at some point you'll hit a wall with only a 512GB C:drive a few years down the road  your specs on screen look pretty good for AutoCADARCH.
rwrightWMDSY
Have to agree with that.  Today's software takes up a big chunk of hard drive space.  That 512 GB will fill up fast when you start installing more apps.  I would go for at least 1TB primary drive.
tevansHMH
I would change it to an i7 cpu, at least 8 gb video card (if doing 3d even more), 1 tb hard drive
