Inserting a door doesn't cut into the wall anymore
Message 1 of 12
Just out of the blue, inserting a door into a wall, any type of wall, the door gets inserted but the wall doesn't cut an opening. The wall still shows up going thru the opening of the wall. 'I've have tried display setting from Low Detail to Presentation with the same results. Anyone with some ideas on what's going on.
Mike Message was edited by: mmyers
Replies (11)
Message 2 of 12
Here is example of what I mean with the attached file.
Message 3 of 12
Are the sill lines turned on in the sill display rep?
Charlie
Message 4 of 12
eviele
are both the door and wall at an elevation of 0?
Message 5 of 12
What Display Configuration is set current, and does the cut plane cut through the doors?
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006, 2007 & 2008 at home
Message 6 of 12
Can you attach a sample file with just one wall and door from the same file.if the actual file is not heavy, you can attach it directly.This will make it easy to solve the issue.
regards,
T
Message 7 of 12
I believe the sills are turn on. The cut plane is set to 0 and the doors don't cut thru and display setting. Here is the example file that you requested. Please let me know what you find out.
Thanks Message was edited by: mmyers
Message 8 of 12
your door is below the cut plane its only 8" tall.
wrote in message news:[email protected]...
Message 9 of 12
I really feel about 8" tall right now
Mike
Message 10 of 12
ahh, we've all been there in one way or another.
Mike
Message 11 of 12
Yes.very True.i had a look.The door height is small , so that it is below you global cut plane.The global cut plane is the one which you can find in your drawing status bar.You can increase the door height, or adjust the global cut plane height so that the door is cut.
Also, to add :
1. You can have a global cut plane in your project.
2. You can have a forced cutplane for the wall, where it will override the global cutplane
3. In the door style display configuration, you have the option to make the door respect the cutplane of the wall or respect the global cutplane.
Hope this helps.
Cheers,
Tharakesh
Message 12 of 12
very simple
The wall phase is different with the door phase
check how to change the phasing on youtube
