In AutoCAD architecture 2026-lock other objects when editing block in-place?
baleti3266
baleti3266
Is it possible to lock other (faded) objects while editing a block in place? That seems to be default behavior already when editing Xrefs in place, but when I'm editing blocks it seems that I can still move/stretch other objects (even though they are faded).
imadHabash
The normal behavior for this procedure is to be locked!!!
Which command did you use for editing the block?
Which version of AutoCAD did you use?
Can you make a short video for your issue?
Imad Habash
cadffm
start REFEDIT command, switch to SETTINGs Tab, turn on the Lock option.
Sebastian
baleti3266
@cadffm you are right this behavior is controlled by this "lock objects not in working set" being ticked off
by default it's ticked on, but I set an alias that run it:
(defun C:rf () (COMMAND "-refedit" "ok" "all" "no"))
and for me on start this put it in "lock objects" turned off state
sadly there doesn't seem to be a way to control it other than running refedit once manually for each new drawing
after refedit (without hyphen at the beginning) runs once, -refedit runs again with locking turned on
@imadHabash
autocad architecture 2026
this sounds like a bug in autocad? should I report it? or ask them to expose a variable or -refedit argument to control it?
cadffm
Default value for a new fresh standard installation is ON, right.
>>but I set an alias that run it: (defun C:rf () (COMMAND "-refedit" "ok" "all" "no"))
That's limited to preselected blockreference, okay.
Why not (defun C:rf () (if (ssget "_i") (COMMAND "_.-refedit" "_ok" "_all" "_no")(COMMAND "_.-refedit" pause "_ok" "_all" "_no"))(princ))
No, that has nothing to do with the lockobjects setting.
Why do you think so, Are you able to replicate that? -> Ahhh, your next statements explains
So the setting is correct (think about, the setting is saved by profile, so it's possible that it is ON in one, but OFF in another profile / User)
but it doesn't work for -RefEdit, until you runned command RefEdit one time (per drawing file).
Yes, because it works if you runned RefEdit and this can't be designed for. If it would never work, it could be designed this way.
>>"should I report it?"
Yes, why not- decades old bugs are still bugs.
Sebastian
baleti3266
it seems that it's ON for REFEDIT, but it's OFF for -REFEDIT (until you run REFEDIT once, after that it's ON for -REFEDIT too)
thanks, that looks more robust
is that normally done via this feedback page?
Sending Product Feedback to Autodesk
