How to have a specific area in an irregular shape?
Message 1 of 19
I modeled a form for my design project and now I have to scale it so floor areas have a specific amount (for example each floor should have 500 square meters area). I tried doing this with scale factor but because its original area has numbers after decimal I cant get that exact area that I need on each floor.
Am I doing something wrong? Is there another way?(Im using auto cad 2018)
Replies (18)
Message 2 of 19
CADmonkey_UK_Building_Services
On a real building site there is a tolerance of +/- 25mm. Maybe don't worry so much about getting 500.0000 square metres.
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
Message 3 of 19
Thank you for your reply. I just wanted to know if there is a way to get the exact area if not I’ll do exactly as you said.
Message 4 of 19
Maybe create a Block of your object? Then you can scale X and Y individually. This might help you find a way of calculating an exact scale factor.
Type DDUNITS to change how many decimal places are displayed (max=8).
Message 5 of 19
dbroad
Given the existing area, scale the object by the square root of the ratio of the desired area divided by the current area.
Architect, Registered NC, VA, SC, & GA.
Message 6 of 19
Thanks for replying
I’ve actually done the things you’ve mentioned but they didn’t help
Message 7 of 19
Thanks for replying
I’m not really good at understanding English mathematics. Do you mean:
(current area/desired area)² =scale factor
Message 8 of 19
David_W_Koch
@Anonymous
I believe what he meant is this:
So, if the current area is 100 square meters, and the desired area is 150 square meters, the scale factor would be approximately 1.2247448713915890490986420373529.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 9 of 19
Yup that'll do it
Message 10 of 19
Yes because the scale factor is not accurate the desired area won’t be accurate ether . Is there no command or sth that I don’t know of in autocad that allows you to change the area of any shape to the desired number without using scale factor.
Message 11 of 19
Now I'm confused. How is the scale factor "not accurate"? With DDUNITS you can display fractions of a millimetre to 8 decimal places.
David's formula works for me.
Message 12 of 19
Looks like I’m not really good at explaining this In words. When I say its not accurate I mean the scale factor gives an area like 498.98 instead of the exact area of 500 because the scale factor might be a non-integer number
Message 13 of 19
And when you remove the decimals it doesn’t mean that they’re really gone (I tried it and still got the same result)
Message 14 of 19
David's formaula, applied to the numbers you mentioned, would look like this:
square root of (desired area / current area)
= square root of (500 / 498.98)
= square root of (1.0020441701070183173674295562948)
= 1.00102156325776435162615327964 (paste this into your command line as the scale factor)
Message 15 of 19
I know how to use the formula and how to get a very long decimal for scale factor but I’m just trying to find deferent method sth that does not include scale factor calculation
Message 16 of 19
Scaling seems like the best, if not the only, tool for the job. Can you provide more details?
Message 17 of 19
Looks like there’s no other way other than scale factor in autocad for now. Thanks again for your reply
Message 18 of 19
dbroad
@Anonymous  Sorry but I've been busy today.  This is what I did, starting from a polyline.
  1. Select the object.
  2. In the properties palette, select the calculator button next to area.
  3. Copy the value (CTRL+C).
  4. Start the scale command. Pick the object to scale. Select a basepoint and when it asks for the scale factor, enter
    'cal sqrt(<Desired area>/CTRL+V)
I marked my first response and David's as the correct answers. It is expected that the post/s that answer the question are accepted as solutions rather than the post that accepts the solution. I unmarked your response as a solution.
Message 19 of 19
Thank you
