I am exploring AutoCAD Architecture.
Could some one help me on the following.
Thanks.
Solved by R_Tweed. Go to Solution.
There are a couple of ways that I know to renumber your room as shown.
1. Manually select the space and use your properties palette. Go to the extended data tab and you will find number under space objects.
2. on your annotate tab there is a scheduling pull down section that has a renumbering property sets command.
Great help. I am happy with both methods. I appreicate it. Thank a lot. I got it.
