How to do Publishing in 2014
octavio2
octavio2
1. Please advise or provide a link to a good brief and readable article on instructions of how to "Publish" a set of drawing fromw the layouts in version 2014. (are these binded PDFs?)
2. The same instructions work with version 2015?
3.  The instructions are similar for vanilla AutoCAD?
3. Are final outputs PDFs?
Thanks in advance.
pendean
Community Legend
Community Legend
PUBLISH command and function hasn't changed in 15-years: there are hundreds or blogs, tutorials and YouTube videos explaining usage. Use your favorite web search engine and explore.
Victoria.Studley
Hi Octavio,
Here are some links that will help you familiarize yourself with the publishing options in AutoCAD Architecture:
About Publishing
Publish Dialog Box
Commands For Publishing Settings
To Work With Publishing Options
To Work With Publishing Jobs
About Publishing Drawings to PDF
If you are using Sheet Sets, the following might also be of interest to you:
To Modify a Sheet Set for Publishing Using the Publish Dialog Box
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
octavio2
Very good links in a good readable sequence.  Thanks a lot!
Very interesting and useful tips I think.I read step by step this informations and help me so much.Thank you for this great informations
