Message 1 of 12
how to create 3d terrain from contours
hello, i am trying to create a 3d solid from a file with contours i have. this file is attached below, and also has elevation points, buildings, and water. only the contours have an elevation yet, and that's all i need for now, but i can't figure out why i can't make a solid terrain. i have access to autocad educational, but no other autocad options.
i have tried using the loft command, and then thickening the mesh, but i get an error 114066 code.
i have tried using drape command, but i have autocad educational, and it does not exist (command not found).
i am trying to get what i have (in the file), to look like the image i also attached below. any advice or help for autocad educational would be appreciated, thanks!
