Hatching Issues
Hatching Issues
Hatching Issues
I am having issues with the hatching command, in that when I scroll down the drop down library, about 3rd down it freezes and I have to reboot the program.
I can get round it by typing HPDLG which brings up a different menu, but not how I want to !!
any ideas ?
pendean
Community Legend
Community Legend
ACA version is what?
Windows OS is what?
Is this a sudden new problem in ALL files, or is the problem in this one file?
You might need to turn off HPQUICKPREVIEW and GALLERYVIEW variable as your graphics card can't seem to keep up with AutoCAD otherwise.
That's for the quick response.
AutoCAD Architecture 2016
Windows 7
It is an issue that has only just started and seems to be on every file
tried the toggles suggested, still a problem !!
regards
Steve
David_W_Koch
Have you (or your firm) added any hatch pattern files anywhere on your AutoCAD search path recently (at or before the time the problem first occurred)?  If all of the problem files tested so far are from the same folder, check there, too.  Could be there is file that is for some reason giving AutoCAD a hard time - perhaps some sort of error (although it usually just ignores those) or a very dense pattern that is taking an inordinate amount of time to generate a thumbnail.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Had to IT to re-install my profile, I had conflicting information in my user profile and think AutoCAD was looking to that, possible corrupt hatch file
also ended up uninstalling AutoCAD and re-installing
thanks.
