I have attached my 2d elevation of side view and front view. As you can see the hatch on the front view align with each other. The hatch on my side view does not align with each other. I need a remedy. If anyone can help, I would appreciate it. I have tried all the settings I can think of to fix. When I change the settings, it just swaps the hatch mis alignment to front view.
Solved by R_Tweed. Go to Solution.
You can apply a material surface hatch override while in live section view. This is a pattern adjustment for the material on an object by object basis.
