- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have tried to make a Member Style that has a square column section of 450x450mm from 0 to 8000 in height. From 8000-12000 I would like the column shape be 400x400mm.
I have tried using nodes to make this work but I can never get the column to display properly.
These are the settings I think should work: (the shape is basically a 1 unit square)
Start Shape | End Shape
Component Name Relative to Node Scale XOffset | Name Relative to Node Scale XOffset
1F-2F SQ Start 0 450 0 SQ Start 1 450 8000
3F SQ Start 1 400 8000 SQ Start 2 400 12000
Does the X Offset always refer to the Member's start point or the the previous node point?
I saw in the instructions about a process to draw a multi-segment polyline, make a rigid frame tool and applying that but it seemed like something useful for a roof beam and not a column. Ideally I would like to have a multi-segmented column where I could snap to a node and stretch it to a floor level to change the location of the shift from one column size to another.
Tips greatly appreciated!
