AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
File name setting in plot/save as
6 REPLIES 6
marymAGTL5
357 Views, 6 Replies
When you go to PLOT the dialogue shows up with the name of the drawing twice & with a (1) after it. Is there a setting that will only plot the file name once?  Or do we just edit the file name for every drawing?
In PUBLISH, the single file name is accomplished by unchecking a setting (prefix sheet title with file name).
See attached/below for what others are seeing with PLOT
6 REPLIES 6
pendean
in reply to: marymAGTL5
Your screenshot is NOT from PLOT command in AutoCAD/ARCH, that's from your 3rd party driver perhaps?
PLOT does not have the built-in ability that PUBLISH has, sorry. But there are many LISP routines out there over the decades that will get you what you want. Try a quick websearch.
marymAGTL5
My screenshot is from the PLOT command when it asks you to name your drawing. We don't have 3rd party drivers.
I use PUBLISH, which you can set the sheet names to be the name of the pdf, if you publish single sheets.
I'm asking about the default naming. Some employees don't use the publish, which I do, and am looking for easy ways to PLOT single sheets without having to rename/edit the name the files each time.
If there isn't a setting for that, then that's an answer. But I recall the single sheet plotting would not have a double name or the () in the name. Granted that may have been many many versions ago. I wouldn't even know what key words to use to find a LISP to name the single sheet plot the name of the sheet, or if my company would even accept something like that to be used.
pendean
@marymAGTL5 wrote:
My screenshot is from the PLOT command when it asks you to name your drawing...
That's your 3rd party PDF driver's pop-up, that's not a function of AutoCAD/ARCH. it was triggered from PLOT command, but it is not a native AutoCAD/ARCH feature or ability. HTH
@marymAGTL5 wrote:
...If there isn't a setting for that, then that's an answer. But I recall the single sheet plotting would not have a double name or the () in the name....
Sadly that's never has been an OOTB ability or feature in any year version unless you implemented a customized LISP or used a third party add-on. But the latter is the solution(s), lots of those out there you can use (with modifications of course).
R_Tweed
Could you expand your image for plotting.  I am using aca 2023 so my view may be different.
marymAGTL5
in reply to: pendean
AHH I see what you are saying now. I'm wondering if it's Bluebeam that is creating this setting (3rd party). I've been using the 'plot to PDF' for so long that I never considered the interaction between the two programs.
Well! Time to head over to BB for answers.
marymAGTL5
in reply to: R_Tweed
See my response to @pendean
We use Bluebeam PDF, whereas you are using the AutoCAD dwg to pdf.pc3. I think BB may be the issue. Need to investigate further into that program.
