Field with custom object properties
marcin.sachs
marcin.sachs
Hi All,
There is any way insert field with custom object properties?
For example I have custom properties for 3d Solid (in extended data) and I wont to insert text with field to this properties.
dbroad
Not with the field command. Create a tag that reports the property and add that to the drawing instead.  You can also schedule the property sets. ACA was ahead of AutoCAD in scheduling but chose a different route.
Architect, Registered NC, VA, SC, & GA.
marcin.sachs
@dbroad
Thank you very much for reply. I know about tags because I'm using this but in model. I was afraid there will be no possible attached  object in model space to tag on paper space. I was wrong. Now everything working perfect for me.
dbroad
Glad it worked for you.  As for myself, the only annotations that I put in paper space related to plans, elevations, sections, and details are the view titles, titleblocks, and general notes.
