Fatal Error unhandled e0434352h exception at 7c812afbh
Message 1 of 10
We have a 32-bit machine that continues to receive the above mentioned error message. This seems to happen unexpectedly and closes AutoCAD with no warning. It has been happening with more frequency lately. What causes this error and what steps may be taken to remedy it?
Thanks for any help anyone is able to provide.
Replies (9)
Message 2 of 10
Also getting this same error.  Tried removing all dotnet installs; ran dotnet cleanup; reinstalled dotnet v2 sp2 through v4; ran windows updates; ran autocad repair.  This is on AutoCad Architecture 2012.  Getting error after opening files.
Message 3 of 10
Sergio.Bertino
Autodesk Support
Autodesk Support
Hi
Please try the solution posted on our blog:
http://upandready.typepad.com/up_and_ready/2011/08/autocad-family-exception-in-acmgddll-arx-command-...
Sergio Bertino
MFG Technical Support Specialist
Message 4 of 10
The 2 machine.config files already had Read and Read & Execute.  Your error message is a little different than what we are getting.  Thanks though for the post.
Message 5 of 10
Sergio.Bertino
Autodesk Support
Autodesk Support
Please try the following:
Sergio Bertino
Message 6 of 10
We ended up removing all versions of .net Framework, then reinstalling those that were necessary.  Then we performed the repair for AutoCAD.  We do keep Windows updates current.  That did not seem to remedy the problem.  However, we've not had any additional problems since we updated the graphics card driver.
Message 7 of 10
RonObvious
Observer
Observer
Thanks Sergio, it worked for me. Probably the problem was with MS Visual C++ files..
Message 8 of 10
Hello Mr. Bertino,
has the solution for this problem:
Fatal Error unhandled e0434352h exception at 7c812fd3h
I installed autocad 2012 on 32bit Win XP sp3 demo
Francesco
Message 9 of 10
mail
I suddenly had that message when starting AutoCAD on Windows XP. The proposed solution corrected the problem.
Message 10 of 10
arshadmirza786
Unfortunatly I have moved to windows 10 x64 and have the message
"FATAL ERROR: Unhandled e0434352h Exception at 929aa1c8h"
may I go back to win 8.1 x64 or have any remadiy for it
