Fatal error Unhandled Access violation Reading 0xfffffff
Hi there ;
I am using AutoCAD architecture  2018 onto my computer. After getting my constructs ready, I am trying to create views. It just does not work  (worked once before and stoped)  and immediatly I received this error, “Fatal error: Unhandled Access violation Reading 0xffffffff Exception. I am wondering if anybody knows what that error is signalling and could help me resolve the problem. Thank you!
 Machine name: LAPTOP-SP01RFR5
Operating System: Windows 10 Pro for Workstations 64-bit (10.0, Build 16299)
 System Manufacturer: LENOVO
 Processor: Intel(R) Xeon(R) CPU E3-1505M v6 @ 3.00GHz (8 CPUs), ~3.0GHz
Available OS Memory: 16190MB RAM
Card name: NVIDIA Quadro P3000
Manufacturer: NVIDIA
Chip type: Quadro P3000
DAC type: Integrated RAMDAC
Accepted solutions (3)
https://forums.autodesk.com/t5/installation-licensing/fatal-error-unhandled-access-violation-reading...
here's a link to a similar issue someone posted on the forums previously, maybe it will help.
@Anonymous wrote:
Hi there ;
@ Processor: Intel(R) Xeon(R) CPU E3-1505M v6 @ 3.00GHz (8 CPUs), ~3.0GHz
Victoria.Studley
Hi @Anonymous,
Do you have at least one drawing file open at the time that the crash occurs?
Does the crash subside if you have at least one drawing open when you create new views?
See this similar thread.
If one or more of these posts helped answer your question, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Victoria.Studley
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided Monday work for you?
If so, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
