Extracting Hatch Pattern Files from Drawing
zaktorres
zaktorres
Is there a way to easily extract hatch patterns from an existing drawing?
I get a lot of drawings from a bunch of different designers who use various software programs, and their hatch patterns show on the drawings correctly, but I am unable to modify the spaces, scales, etc. I would like to extract the hatch patterns if that's possible. It is not feasible for me to ask all of the original designers for their hatch patterns and I don't want to have to find patterns online that are similar.
For instance, here is a stone pattern one designer uses. It shows on the print correctly, but since I do not have it in my .pat files I am unable to select additional spaces for it to fill.
I have looked through the forum, and haven't found a solution; I would like an answer and not a remark to keep looking.
pendean
Community Legend
Community Legend
There are many LISP that extract hatches on the web: but if that hatch replies on a custom shape file, then you might just be out of luck @zaktorres
Options:
1) why not ask the file creator for that hatch? easiest solution ever.
2) GETPAT is a free LISP, you can pay for similar routines too
https://sourcecad.com/export-custom-hatch-pattern-in-autocad/
https://www.google.com/search?q=autocad+getpat+lisp
3) build your own library from free content
https://coronado.com/hatchpatterns/
https://architextures.org/hatches
https://www.cadhatch.com/free-downloads
HTH
zaktorres
  1.  We deal with over 60 original designers whose projects span the past 30 years and are made across various software programs, so requesting pattern files may be unreasonable or impossible, I am not aware how other software  programs handle their hatch patterns.
  2. I have tried the GETPAT lisp and have had issues with it working properly; I am not sure if this is a function of it being a 25 year old lisp program that has not been updated.
  3. I have used some of those hatches and they are helpful. I was hoping to add the existing hatches to my pattern library, so that I did not have to change the pattern definition with every new project.
    Thank you for the response.
zaktorres
I found another thread when I was looking at the error I was getting with getpat.lsp file, and it had an updated lisp file that works
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/getpat-lsp-error/td-p/6974597
