When i export PNG by using PlottoWebPNG.pc3 with the paper size have more than 70000pixels width, this happened
I tried 100000pixels height but there is no problem, i dont know if there is any limit of the width or not
Thank you for you answers, this is the images of the problem
I export the PNG from autoCAD, by using PlottoWebPNG.pc3 and create paper size (pixels), there's no problem when the paper's width < 70000pixels but when the width > 70000pixels, the objects in the rightside just overrided the leftside, it's like there's a limit about the paper size, but when i tried the height > 100000pixels, there's no problem.
The bottom screenshot was from Photoshop, i used it to open the PNG file after exporting from autoCAD, the first screenshot is the image i wanted to export, there's no error in the preview but the result is the second screenshot. i will be grateful if you can solved this problem.
Thank you very much for your reply.
