@Shaye_Clements wrote:
Thanks for the quick response. I'm helping an outsource that is running 2024 but just found out she doesn't have any AEC Content loaded, which affects the SPACE commands. Loading the AEC Content should fix the SPACE problem.
Thanks again.
That can mean two things:
1) they did not actually install AutoCAD ARCHITECTURE 2024, just AutoCAD. Ask them to send you the program's ABOUT command pop-up s a screenshot. It should look like this
2) They are running ARCHITECURE "as AutoCAD", nd they need to activate the correct profile in OPTIONS command's PROFILE first instead of the "autocad" profile
