I have been trying to edit a wall using sweep but, I just seem not to get it. Attached are two images, walls and 3d solids. 3d solids in what I want to achieve
Wall Sweeps in AutoCAD Architecture will not do what you show. They can add a non-rectangular profile to a horizontal component (such as a chair rail), but they will not be able to create an non-vertical Wall End. To achieve that end result, you can use a Subtractive Interference.
Hi @Anonymous,
I see that @David_W_Koch provided a great suggestion to help you achieve the kind of wall adjustment you're looking for. Did this help you with your walls, or do you more guidance?
