Dynamic block with classification and property set definition
tevansERD
tevansERD
I have created a dynamic block of a grab bar using the stretch and look up actions. I need to attach a classification and property set definition to it so it will schedule. I do not see a way to do this. there isn't a dynamic block option in the applies to table. Does anyone know of a way to accomplish this?
David_W_Koch
Dynamic Blocks are still considered Block References, so you can create an object-based Property Set that applies to Block References and attach that to your Dynamic Block instances.
You will not be able to create a Classification Definition for one, however.  Those only work with AEC objects.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
tevansERD
so i cant schedule dynamic blocks if the schedule uses classifications?
David_W_Koch
Not exactly.
In order to even use a Classification on the Applies to tab of a Schedule Table Definition that applies to Block References (or other non-AEC objects), the Classification Definition has to apply to all objects.  (I used the Select All button to select all objects; not sure how it works if you manually select each toggle.)  That will allow Block References to appear in a Schedule Table that has a Classification Definition specified on the Applies to tab, but you will only be able to use the Classification Definition to filter AEC objects, like Multi-View Block References.  All instances of Block References (or other non-AEC objects) will appear in the schedule, as there is no way to specify one of the Classifications for Block References.
David Koch
Blog | LinkedIn
dbroad
Why not use dataextraction instead?  Don't try to fit a square peg in a round hole.
Architect, Registered NC, VA, SC, & GA.
brian_adams
Well sorry for self mentioning but i wrote a topic about block reference and scheduling it.Take a look to second message
In some reason I wrote not lookup but pickup...Try it for your issue
https://forums.autodesk.com/t5/autocad-architecture-forum/precast-elements-using-block-references-ti...
Tiana_Y
I'm just checking in to see if you need more help with this. Did the suggestions that @David_W_Koch@dbroad and @brian_adams provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
