- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am having a scaling issue in Autocad Architecture 2018. It used to be that if I changed my acadiso units to meters, I had to go in and change the scales, the dialogue said ___ paper units = ___drawing units, so for 1:1000 I would write 1 in the first blank and 1000 in the second. Now it says ___paper mm = to ___drawing meters. If I now make a 1 to 1000 scale, which would imply 1 paper mm equals 1 drawing meter, the program does the wrong math and the actual scale is 1! This math checks out if the dialogue had not changed, aka 1 paper unit equals 1 model unit, but because the wording has changed this no longer makes sense. So for now, I have to write 1 paper mm equals 1000 drawing meters to get .001 scale, which is wrong but is apparently what works. Am I missing something here or are added mm and meter captions actually wrong?
