AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Door Scheduling
1 REPLY 1
tevansHMH
456 Views, 1 Reply
Door Scheduling
tevansHMH
We want to standardize our door numbering so for example the front door is always 1, a 20 door is always 10 etc. I have created a door style for each size door and preset the door "Mark" to what we want the standard to be. But when i insert the door into a drawing the mark is 0. The PSD for the mark is set to integer. What am i missing in the setup?
Door Scheduling
1 REPLY 1
David_W_Koch
in reply to: tevansHMH
David_W_Koch
Is the Mark Property part of a style-based Property Set?  If it is, then you could set a value for each Door Style and have it stick.  If it is in an object-based Property Set, then even if that set is attached to an instance in a source file, it will not carry through when placing a Door via a tool palette tool.  (I believe the same is true when using the Styles Browser, but have not tested that theory.)
If you always want a Door of a given Door Style to have the same Mark, place the Mark Property in a style-based Property Set.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
David Koch
Blog | LinkedIn
