DOOR SCHEDULE-REPEAT VALUES PROBLEM
Richard.Vivanco
Advisor Advisor
Richard.Vivanco
Hi
Im creating a new doors table style.   I need the number and quantity properties, but when the number property is included, the quantity not show consolidate, same door with same dimensions are repeated.  It only works fine when i delete the number property.  But in the other hand i need the number.....
Is there a way to combine both properties without problem?
Thanks.
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Youtube | LinkedIn
autodesk 3DS pro
dbroad
Did you edit the style and check "Include Quantity Column"?
If the other properties vary per door number, you may also need to add a subtotal to the mark column or to modify a pre-existing one (as in the sample project) by checking the group box and the display subtotals for group. That will also require editing the quantity column to include a total. The image below is a modified sample project file. Note that even though mark numbers may be the same, other properties vary.
Architect, Registered NC, VA, SC, & GA.
Richard.Vivanco
Hi
In which property set appears the MARK properties?  Im using NUMBER property instead, because this is the value that appears in the door tag.
Richard Vivanco V.
Youtube | LinkedIn
autodesk 3DS pro
dbroad
Mark (in the title) is the door objects number property.
David_W_Koch
@Richard.Vivanco wrote:
Hi
For objects to be consolidated on one line in an AutoCAD Architecture Schedule, ALL of the property values in the schedule have to be the same.  If you have a different "Number" for each door and include that in the Schedule, then all the Doors will be on separate lines.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Richard.Vivanco
Thanks for the answers.
Richard Vivanco V.
Youtube | LinkedIn
autodesk 3DS pro
