I am coming back into the AutoCAD world after years using Inventor, and I'm a bit frustrated with the units issues. We are using architectural dimensions, which is fine, but when I use the measure command, I would like to get a more precise number than just whatever the dimension style is. Is there a way to get the measure command to display results in a decimal format without having to change my dimension unit format?
