DIMS ISSUE
DIMS ISSUE
Jacob.Riley
Message 1 of 8
DIMS ISSUE
Jacob.Riley
Can anyone tell me how to fix a problem with my dimension flipping from horizontal to vertical and vice versa when I pull the extension line back to the arrow.
Replies (7)
Message 2 of 8
leothebuilder
Are you using regular autocad dims or Aec dims in ACA?
Message 3 of 8
Jacob.Riley
Regular Auto Cad
Message 4 of 8
leothebuilder
When you say "pull back extension line to the arrow" I assume that you want your extension line to disappear.
If that is what you want to do, you should select the dimension and on the properties palette turn off the extension line.
The advantage is that the defpoint will still be at it's original location.
You can turn of just one or both extension lines using the properties palette.
If you want this for all dimensions I would create a dimension style and with the extension lines suppressed.
Message 5 of 8
Jacob.Riley
Yes I want the extension line to disappear but I dont want the arrow to disappear which is what will happen if you use the properties pallet.
Message 6 of 8
leothebuilder
No.
If you just turn off the extension line the arrow will not disappear.
Unless maybe you have a custom block arrow?
Message 7 of 8
Jacob.Riley
My appologizes I turned off dim line and it shut off everything on the side shut off.
Message 8 of 8
leothebuilder
Ok, glad you've got it working.
