AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Dimensions won't associate
13 REPLIES 13
Message 1 of 14
uwdawgs
3054 Views, 13 Replies
I'm doing some dimensions to an apparent intersection (using object snap tracking).  I get the yellow exclamation point saying it is a Disassociated Annotation.  I tried to reassociate it, but it still has the yellow exclamation point.  It is a bit annoying, but I decided to just ignore it.  I saved my drawing and then later when I reopened the drawing I noticed the dimension had changed and wasn't going to the apparent intersection point anymore.  Luckily I noticed and fixed it, but I am worried it will happen again.  Any ideas how to associate the dimension or keep it from changing in the future?
Labels (1)
13 REPLIES 13
Message 2 of 14
dbroad
in reply to: uwdawgs
I believe that is a program limitation.  Apparent intersections are calculated for a particular projection.  If you make changes to the geometry, you will need to reestablish the location manually.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 14
uwdawgs
in reply to: dbroad
That would be fine if I made changes to the geometry, I would be ok with
having to update the dimensions. The problem is I didn't make any changes,
but the dimension had moved from that apparent intersection to a nearby mid
point.
Message 4 of 14
dbroad
Please post a small drawing that replicates this behavior along with instructions on how to trigger the dimension to move itself.  In my experience, this never happens without user interaction, either accidental or intententional.
Since you are posting in the ACA newsgroup, are you referring to changes with respect to AEC dimensions or ordinary dimensions?  Are the objects being dimensioned AutoCAD or AEC objects?  Are there xref's involved (constructs, elements, views, etc)?
Message 5 of 14
uwdawgs
in reply to: dbroad
Thank you. I am using AutoCAD Architecture, but ordinary dimensions to
ordinary lines. No xrefs, constructs, elements, or views, just regular
model space. I just started using Architecture and haven't incorporated
much of the features yet, but hope to use more as I learn more about it. It
looks like what happened was the dimension changed from the apparent line
intersection to a nearby line midpoint. It has not happened again after I
fixed it. I still have the yellow exclamation point and was just worried
the dimension might change itself again and I wouldn't notice before I
print. I put a point at the apparent intersection and redimensioned it
snapping to a node hoping that would associate it, but that didn't work
either. Just wondering if there is some trick to get it to associate.
Message 6 of 14
pendean
Message 7 of 14
dbroad
Without a drawing to look at, it's all guesswork.  I suggest you turn off annomonitor to keep you from worrying about the warning flags.  A dimension isn't truly associative unless both definition points of a dimension are associated by object snap to objects.  The only ways that I know to reassociate a dimension are to either use dimreassoc or to delete and recreate the dimension using object snaps for both definition points, assuming dimassoc is set to 2.
Don't assume that associative dimensions are correct BTW.  Look at them just as critically as non-associative dimensions when checking. Deleting a vertex in a polyline can play havoc with associative dimensions.
Message 8 of 14
uwdawgs
in reply to: pendean
It's set to 2. Thanks. I knew how to turn the yellow exclamation points
off, they're only a minor nuisance, I was just hoping there was a way to
make the dimension associate to the apparent intersection so the dimension
would be associated and the yellow warning would be gone.
Message 9 of 14
pendean
"A dimension isn't truly associative unless both definition points of a dimension are associated by object snap to objects" is sage advice to your issue.
Message 10 of 14
uwdawgs
Ok. Thank you. So I guess a point isn't enough to qualify as an object.
Message 11 of 14
dbroad
We didn't say that.  That's an incorrect conclusion. I put points inside blocks all the time and dimensionally snap to them and the dimensions are associative.  A linear dimension requires that both definition points snap onto objects while dimassoc is 2.
In addition, when snapping to the center of a circle, the process associates the circle with the dimension without the definition point being on an object.
Message 12 of 14
uwdawgs
in reply to: dbroad
Thank you! I just tried putting a point at the apparent intersection again
and snapped to that and now it is associative. Not sure why it didn't work
the first time I tried it.
Message 13 of 14
David_W_Koch
For the record, a POINT object does qualify as an object to which an associative dimension can be anchored.  Using an APPINT snap while dimensioning does not create a POINT object at the apparent intersection location.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 14 of 14
uwdawgs
in reply to: David_W_Koch
That's weird, I put a point at the apparent intersection. Snapped to the
node and it was associative. I even moved the point and the dimension
updated.
