Dimensions are not showing when I'm trying to draw
parman09
Observer Observer
parman09
Observer
Observer
Hi everyone,
I have a problem in Autocad2024. I was drawing a staircase, unfortunately I messed up something on the keyboard and since then I can't see the dimension when I'm trying to draw. I have restored Autocad, set Dimension Input Setting, PICKFIRST, F12 - nothing helps 🙂 When I start drawing new ones, there it goes fine, so I don't understand where the problem is. If I copy the old one to the new drawing, it doesn't help either. I am attaching a screenshot. Thank you very much for any advice.
pendean
Community Legend
Community Legend
Which layers do you have turned OFF that probably need to be ON?
same with FREEZE.
parman09
Observer
Observer
I have only one layer, there's nothing that looks strange, but when i start drawing a circle into the stairs, it's showing normally.
pendean
Community Legend
Community Legend
@parman09 The only difference I see between these two images is your DYNMODE appears to have been turned off
Have you installed the 2024.1.6  Update yet? ABOUT command in your AutoCAD will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards please.
