I really don't know how else to explain it, so I've made a screen recording to show what's wrong. Basically, at some point I must've accidentally changed a setting and now the dimension strings are moving like this (look like they're grid snapping when snap mode is off, not referencing certain points that they were before):
Before this problem happened, the dimensions would snap to the edge of the ellipse of that door tag, and I would be able to drag them straight back to reference an outer wall line. It's not a problem that affects all my drawings, just certain ones. Anyone know what's going wrong (and I can provide more details if need be)?
As for my OSNAP settings, here's what I've got:
I'm not sure what block you're referring to, though; I set up a couple of rectangles and a generic door tag just to illustrate the problem. Do you mean the dimension string itself?
You wrote: "..I'm not sure what block you're referring to..."
How about the one you are trying to click on called TAG-door
Which when you explode (as I suggested) shows that it is an ellipse with only three locations that you can snap to, no where else (see the blue dots)
So there appears to be no option for you to snap anywhere else on it accurately, but you can fudge it with a NEAREST hoping for the best (which no one really likes in CAD, it is considered sloppy)
May I ask why are trying to dimension to a floating unrelated tag when you appear very concerned about dimensioning the rectangles instead? Why not dimension to the center of the line instead?
I see what you're saying. I have these rectangles set up as an example; what I'm working with is similar, with different finish lines/stud lines along a wall. I put my door tags in the middle of a door opening, then I attach the dimension string to the center of that. What's confusing me is why I can't snap to anything I want as long as it intersects with the line along which the dimension callout runs, if that makes sense.
It's not a problem that's stopping me from getting anything done, obviously, but it's annoying that it's not acting normal. I'm really new to doing this kind of thing (intern moment), so I'm also probably not using the best practices or what have you. I was hoping it was just a simple matter of a setting that I accidentally changed, but I haven't found anything on other posts about it (partly because I find it so hard to explain). I really appreciate your help so far though.
(my selected objects are stripy now instead of blue, which is another interesting development)
I attached the fixed DWG in case you wanted to take a look at that one too. I'm going to leave this case open in case anyone who's encountered this problem comes along and can say whatever setting it is that I must've messed up (or if it's a glitch, if there's a faster way to fix it). Once again, thanks for your help!
