AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Difference between AutoCAD and AutoCAD Architecture?
5 REPLIES 5
42497 Views, 5 Replies
I want the detail difference between autocad versus autocad architecture !
@Anonymous for clarity VStudley edited the original subject: Autcad Architecture
5 REPLIES 5
have you tried searching the internet for this info?
pendean
AutoCAD is a general use CAD program to draw/design anything/everything, with no easy ability to do anything architectural without a lot of work on your end all up front.
AutoCAD Architecture has tools for architects and builders to design buildings with, ready to go.
If you want more, go to YouTube and watch videos to see for yourself, and explore Wikipedia for more info.
Sridhar-Autodesk
Please see one of the old productivity study attached.
Sridhar Subramani
Senior Product Owner
Victoria.Studley
Hi @Anonymous,
Welcome to the Autodesk Community!
I'm just checking in to see if you need more help with this. Did any of the suggestions provided here help answer your question?
You may also want to review these resources that compare AutoCAD to AutoCAD Architecture:
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
jwverde
I think AutoCAD architecture is essential for productivity.
AutoCAD is good for the basics, but has limitations.
Once you upgrade to Architecture, you won’t want to go back. Totally worth the $$$$.
Best Regards,
Joel Westervelt AIA
Vernacular Architect
Instagram | Facebook
