Define a custom room tag?
Hi all,
   I want to define a custom room/space tag, that will read the area and name of the space and display it automatically as text, how would i do it? the ACA help does not have any clue on how to "defining custom room tags".
David_W_Koch
The Help actuallly does have a section on how to create a custom tag.  In the 2011 Online Help, navigate from the "landing page" to Documentation > Schedules and Display Themes > Schedule Tags > Creating a Schedule Tag.  For the 2010 Help (and, likely, earlier versions:  AutoCAD Architecture User's Guide > Documentation > Schedules and Display Themes > Schedule Tags > Creating a Schedule Tag.  That explains how to use the Tag Wizard, which works fine if you want to create an annotative schedule tag that has a single view block.  If those instructions are not enough, you may find this blog article of interest.  That written for the 2006 release, when the Tag Wizard was first introduced, so if you are using 2010 or later, you will have to know that the Tag Wizard is accessed in those releases on the Annotate ribbon tab, on the Scheduling panel.  You will need to click on the Scheduling Panel name to expand the panel, and then choose the Create Tag tool.  Use this in lieu of the pulldown menu instruction in Step 3, and you should be good to go.
You may also want to explore the Content Browser's out-of-the-box offerings, which include the Room Tag (w/ Dimensions) tool which inserts a tag that displays the Space Style, Area and Dimensions.  If those graphics are acceptable, you could modify a copy of that Schedule Tag to show the room name in lieu of the style name and delete the Length x Width display, if you do not want that.  Not that there is anything wrong with creating your own from scratch - I have certainly done that often enough myself.
Should you want to explore additional Schedule Feature resources, you may find the resources and links in this blog article to be of some use.  The AUGI courses are from some time back, but the basic principles described remain valid, even if the interface picks and clicks have changed a bit.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Thanks so much David.
