Cut lines over window cut view plan
ChrisCirrusCon
ChrisCirrusCon
I have tried overrides with the settings of both wall and window but still showing up this way: having the plane line of sheathing and brick line in the air gap of a composite wall. i wanted to show it or behave like it should (having no lines overlapping unlike what is shown) the lines should terminate at the mullions or frame to seal the opening.
Spaup20
Do you have the display lines below box checked on the other tab in edit wall styles?
David_W_Koch
@ChrisCirrusCon
Can you reply post an example file (could have just one Wall and one Window) that exhibits the problem?  Otherwise, we are just guessing as to what settings you have made.
Also indicate what version of AutoCAD Architecture you are using.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
